Brake change at dealership?
Brake light just came on, dealership told me they would soon and quoted me $800 to change front and rear pads and front rotor.
Should I just go ahead and go with them or is it worth the money I could save by going with Just Brakes or Meineke?
I'm not about to purchase and try to do the work myself, and I don't want to end up with inferior brakes.
Thanks for any advice.
I would also stay clear of predatory chain shops like Meineke! Don't be fooled by deceptive advertising.
I bit the bullet and had the dealership do the work. I figured Meineke and the like probably wasn't the way to go but wanted to check with some of you who know.
Thanks for the advice.
New brakes are great by the way. Just like the old ones!!!
Good choice. I got my front pads and rotors a little under $500 at the dealer. OEM parts, so the car behaves just like it did before. Don't know if the cheap pads even have the little sensor built in that triggers when the pads get low.
I can't believe they they charge that kind of money. It's a shame you could not do it yourself as that is almost robbery. Brakes areusually $100 -$200 if you or a friend could have done them and usually pretty simple.
I'm almost due for front brakes. I'm going to buy the ceramic Akebono pads that jagtoes recommended and either do it myself or have my mechanic friend (who will only charge me a reasonable amount of labor) do it. Hopefully, I won't need new rotors yet since I'm only at 56k miles.
