amp and sub upgrade/install advice
Old 11-21-2011, 12:41 AM
imaudi5000's Avatar
Default amp and sub upgrade/install advice
i tried lookin in the electronics forum but couldnt find much info.
i just wanna make sure i dont hit any major snags. im gonna order the sub and amp (and maybe wiring kit) from crutchfield and have Best Buy do the install. im keeping my stock symphony headunit but will the new amp hook up to the headunit, hook up to the factory amp, or replace the factory amp?
any recommendations as to how i should have them wire it? what about keeping the power wire away from the speaker wire? any special tricks for audis?
thanks
Old 11-23-2011, 11:48 PM
imaudi5000's Avatar
anyone?
Old 11-23-2011, 11:55 PM
02quattrokev's Avatar
Yes you can keep your existing head unit and use an aftermarket amp to power the subwoofer. The speaker wires from the back of the head unit will be used as the signal to the amplifier. You will also need the amp wiring kit when installing this.
Old 11-24-2011, 12:09 AM
imaudi5000's Avatar
ok thanks, sounds good
Ultrasport Demon
04-16-2021 10:54 AM
to4xxx
06-02-2012 07:40 AM
joneswashu
06-23-2007 09:45 PM
fher7096
08-05-2006 02:32 AM
Nemick
10-27-2004 04:04 PM
Quick Reply: amp and sub upgrade/install advice
