a4 b7 spot light bulb
Hi Assume you mean the r.h.s of car? The front grille on this side needs to be unclipped and removed. This is done by using a small blade like a terminal screw driver. You will see two clips with a slotted hole in each. Push the blade into the slot and lever carefully to release the clip at the same time gently pull off the whole grille assembly. It is the same on the Left hand side but easier as the cowl on the lhs is a seperate componant. the removal clips are identical though.
daboss085
03-27-2013 08:34 PM
dubgli
02-21-2012 11:07 PM
ssingh
05-20-2011 08:03 AM
