450HP Turbo Kit for B7 Purchased.
just got this:
http://www.atpturbo.com/Merchant2/me...egory_Code=AB7
car info:
2005.5 Audi A4 Quattro 2.0T
42,000 Miles
mods:
APR Chipped 93 Octane
APR Chipped Stock, with lock-out feature.
APR Cold Air Intake
Forge Diverter Valve
EuroSport Cat Back Exhaust Kit
SPEC Stage 2+ Clutch
19" OZ Wheels W/ ToyoProxyes4 Tires
all other items are 100% stock.
Any suggestions on what else would be needed to purchase in order to keep my car safe and sound?
sensors, intercooler, t3 discharge gasket, fuel pump, etc....???
Any suggestions on where to install / tune?
I live in new jersey.
car info:
42,000 Miles
mods:
APR Cold Air Intake
your going to need a new fuel pump, larger injectors, i wouldn;t say you need a FMIC right now but its going to put alot of stress on the dsic you have on there now so if you have the means i would highly recommend you do a fmic
he's got the apr stock engine management there is a more agressive chip out there but its not totally necessary, boost control is going to be taken care of in the ECU a turbo timer is a good idea orrrrrr on a cheaper note you can just let ur car stand idle for like 30 seconds each time u run the car hard
Not bad. I actually have a B7 customer that will be running a HTA35r that he bought from me along with a FX400 6 puck and the very first billet steel flywheel made for us by Clutch Masters. Car will be running a fully built bottom end, larger injectors, APR fuel pump and custom tuning. Goal will be 500whp.
