2008 A4 3.2 Quattro hesitation?
Old 11-21-2008 | 03:38 PM
paleface23's Avatar
Default 2008 A4 3.2 Quattro hesitation?
I recently bought an '08 A4 and noticed the acceleration from a stop (and sometimes while moving) is not very smooth at all. It almost feels like a hesitation while the car shifts from 1st to 2nd. Its my first audi, so, i'm not sure if there is something wrong with my car to where I should take it in...or, if its supposed to drive this way. Its not as pronounced when i'm at speed and the car goes from 4 to 5, etc. But, at lower speeds and especially from 1 to 2, I really notice the shifting between gears. Seems weird that an automatic would feel this way.
Old 11-28-2008 | 07:44 PM
Petergt3's Avatar
You know, I have a '06 A4 2.0T Quattro w/ automatic and I notice the exact same thing. Only between first and second gears the shift is very jerky. I have also heard this from another owner of a 2.0T w/ automatic. I can't explain why this happens, but I think this problem may not be unique to your car.
Old 12-01-2008 | 06:10 PM
sm8681's Avatar
Are you using 91 exclusively?
Old 12-02-2008 | 08:31 AM
Chrisc1100's Avatar
I just bought an '06 A4 3.2 and notice the same thing. It only hesitates if I accelerate slowly, if you step on it, it shifts without hesitation.
This is my first Audi as well, so maybe it's normal?
Old 12-02-2008 | 05:43 PM
dmfan016's Avatar
could be a solenoid issue....maybe getting worn or something that would cause a jerkiness in a shift change in an automatic car
Old 12-03-2008 | 11:16 AM
paleface23's Avatar
Even on a car that's only about 6 months old?
Old 12-03-2008 | 07:47 PM
dmfan016's Avatar
solenoid is an easy enough fix that the mechanic at the shop should have no problem checking out but it does seem early haha
sorry i was looking at the 06 a4 that was also having a similar issue but to be honest i wouldn't totally rule it out
dmfan016's Avatar
especially since u notice the issue only with the switch from 1->2
Old 12-03-2008 | 10:47 PM
Chrisc1100's Avatar
I had mine checked out today by a tech and he said the hesitation was normal for that car...evidently he has an older Audi that does the same thing.
Old 12-04-2008 | 01:29 AM
dmfan016's Avatar
hesitation is never normal an autotragic tranny should shift seamlessly end of story....keep pushing, the tech clearly didn;t wanna get under the car (just wait until ur out of warranty and then all of sudden that very normal hesitation can translate into a **** ton in tranny work)
