2007 A4 Convertible Roof problem, part 2
Old 11-23-2011 | 01:00 AM
jannor's Avatar
Default 2007 A4 Convertible Roof problem, part 2
Hi guys,
so after I had a faulty sensor replaced half a year ago, now the roof is causing problems again: Trying to open the cab, the windows will go down, latches will pop open, but then the roof won't retract. Is the pump dead now?
I have had a sensor in the trunk replaced earlier this year after the roof wouldn't move a single bit and just the roof light would keep flashing at me in the dashboard.
Now the issue is different, but still weird. I wonder if it just needs a reset of some sort... (?!)
It started after I accidentally let go of the (horribly placed) roof switch right in the middle of the closing procedure. Then the roof wouldn't move anymore and I had to manually put it down. After that it worked a couple of times again, until last week, when I tried to close it. The windows would go down and the trunk lid would pop open, but then the trunk lid would not go up further. Nothing would happen. Weird to me was also, that the trunk lid would pop open already while the windows were still going down. I thought to remember that the trunk lid would wait for the windows to go down to their half-way-down position, but I might be wrong here. However, had to put it down manually.
Can the system be somehow reset by disconnecting the battery or something? I've read somewhere else about turning the ignition key 3 times without starting, but that would't help.
Every comment and any help much appreciated!!!
Cheers
Jan
P.s.: I remember now that, after the first incident, at one occasion I had to try several times before the roof closed. (roof was open, tried to close it, windows went down, trunk lid pops up, nothing happens; reversed switch, trunk lid goes back down and windows go up, tried again; on the third or fourth try the roof would close the whole way). This makes me think it is not a mechanical issue, as it worked after the several attempts.
Old 08-31-2012 | 03:27 PM
dasilva377's Avatar
Default Have same exact Problem
Good Afternoon jannor,
Did you ever resolve your issue? Any suggestions?
Thanks.
Old 08-31-2012 | 05:23 PM
Audi Tek's Avatar
Tech Certified
its a faulty pump. 99.9% sure
Old 01-20-2023 | 06:01 PM
DougS's Avatar
2011 Convertible . Top goes down no issue . When closing it rubs on passenger side and makes a popping sound to close at a certain point. Any suggetions on an adjustment?
antonye
05-17-2021 08:35 AM
hughm
B7 Models
06-26-2018 12:57 PM
denlaa
06-02-2014 09:58 PM
malibu
11-12-2011 02:25 AM
geickman
09-21-2007 01:20 PM
