Window regulator busted :(
the driver's window on my '04 A4 started making a grinding noise going up and down and sometimes jamming. Thanks to some posts here I was able to pinpoint the problem right away.
Took the door panel off and found out that the window regulator's cable is tangling up which seems to be a common problem for audis.
My question is, do I need to buy the whole window regulator or do they selljust the cable alone? And if so, should I buy at the dealership? Everything else seems to bein working order
RE: Window regulator busted :(
If your A4 is a Certified Pre-Owned car, the repair will be covered by the manufacturer. All you have to pay is a $50 deductible. I had a window regulator issue myself... the rear passenger window clips broke due to a bad regulator... so I took the car to the local dealer, paid the $50, and got the car back the next day.
Rodneylynn1977
04-11-2010 03:15 PM
