Weird seldom vibration
I don't know if anyone else has experienced this issue before, but I have noticed that when I start the car, then put it in drive and start rolling, the car vibrates violently for about a second as if it's about to stall, then clears up. I'd say that this happens about 10 - 15% of the time. The engine doesn't throw any codes and the scan results show nothing -- could it be a coil pack starting to go bad? Any other thoughts?
RE: Weird seldom vibration
Don't know. But what you are describing is misfiring. On a cold engine one would suspect plugs are not firing for some reason. I would want to pull the plugs and look at them, check the gap. The gap is supposed to be .032 and when I checked mine they were set at .025 - .028, which will cause cold firing. Looking at them will tell you if they are fouled from oil or moisture too. Coil packs are problematic but I would think you would have hot problems instead of cold problems.
There are a lot of varying opinions on which plugs to use. Some believe copperare best and change them at 5k. Platinum are factory plugs and can last 40k. I am using platinum and won't change them until I see them wear. But it really depends on who you talk to and if they have performance upgrades. Perhaps others will add some info here.
cooleststan
06-19-2007 10:15 PM
