Timing Belt Replacement
Hey guys, I have an estimate to get the timing belt in my car changed. And they are telling me 998.60 for the whole job. DOes that sound right? Or should I keep shopping around?
I drive a 2005 A4 1.8T
When I did mine at the dealership they said the waterpump didn't really have to be changed at the same time - I asked them to at least check it out and they said it was fine when I picked it up.
Maybe it's different in Australia, certainly hope so because your not the first person to say that Myst420.
I look at it this way: its only a little more labor and the cost of the part to replace it. Whereas if you don't do it at the same time, and your waterpump goes bad before its time to do the belt again, you end up paying twice as much in the long run because you can't replace the pump without redoing the timing belt.
fritz
08-12-2007 02:55 PM
