timing belt questions
HI i was wondering if there is any way to check your timing belt and see if it has to be replaced, since i'm student i don't have the money just to spend it if is not need it anything helps thanks ....
RE: timing belt questions
Just take off the timing belt cover, and look at the outside of the belt. If it has white marks on it worn into it from the pulleys it needs to be changed. Chances are it hasn't been changed.
