stumped still getting code for cam timing.
Have you checked all your vaccuum lines? I had a really bad leak that caused the motor to pull back timing but because of the leak it wouldnt reach the setpoint and was throwing that very same code, also motor sounded like death and got tons of misfire codes but all thats cleared up now with my new suction pump on the backside of the intake mani
i am aware ignition timing is correlated to cam timing
I replaced the suction pump and smoke tested the car, nothing showed signs of leak except the bov.
also when i log cam timing in VCDS on measuring blocks 90-93 it shows 0 to -1(hops around) for timing.
