Speedometer acting funny.
Old 02-01-2011 | 07:14 PM
treyg's Avatar
Default Speedometer acting funny.
So I was driving today and cruising at about 70mph and my speedometer starting jumping around. Going down to 20 then back up and bouncing around all crazy. After stopping the car for a bit and starting it back up, it didnt do it again but it was enough to freak me out. My experience with issues like this is on American cars and it would usually indicate that the teeth on the speedo gear may be stripped and slipping. I'm not sure if this is the case with my Audi but any help would be appreciated.
Trey
Old 02-02-2011 | 05:29 PM
treyg's Avatar
Any ideas guys?
Old 02-10-2011 | 04:00 PM
treyg's Avatar
Please help. It did it again today.
Old 02-10-2011 | 04:16 PM
ppgoal's Avatar
My old motorcycle speedos would do this when the cable was dry -- they would stick, then release and bounce. A squirt of WD40 fixed it. Or it could be moisture that is icing up. But I have no idea if Audi speedos are mechanican/cable drive or electrical. Good luck and let us know what you find out. It seems no one else has had this problem, hence no responses.
Old 02-10-2011 | 06:16 PM
treyg's Avatar
I got to catch it on video. Take a look.
http://www.youtube.com/watch?v=DTCFmeAjxNY
Old 02-10-2011 | 08:04 PM
pa4ul's Avatar
speed sensor maybe. Im just guessing maybe someone might chime in with a answer. Do some searching on speed sensor.
Old 02-10-2011 | 10:54 PM
auditech79's Avatar
All our cars have electronic clusters, speedo cables haven't been used since the 80's.
If you have a vag com you can do a gauge sweep, go into module 17 and work your way through the output diagnostics until you find it. All the gauges will sweep all the way to the right, then back to the left. If the speedo jumps or malfunctions when doing the sweep, the cluster is bad. If it doesn't, its a VSS (vehicle speed sensor) problem.
magiben2k5
04-22-2015 02:40 PM
johnson90512
05-24-2012 04:35 PM
prady
08-05-2011 06:07 PM
99A4NOW
12-23-2008 11:19 AM
JDCrowe
02-22-2006 05:03 PM
