Smoke around the driver side headlight
Old 09-11-2009, 09:37 PM
dunanga's Avatar
Default Smoking headlight
You are in for a few more surprises, there is no way there could be enough grease on a bulb and enough heat generated by flicking the high beam and resulting in smoke that you can see while in the cockpit! That is an intermittent electrical **** up, sooner or later it will come to stay u will need to check you wiring. Your balast might be arcing on the output terminal, check this out be4 u burn your ride.
audihere
02-16-2018 09:31 AM
fitzisboss
07-29-2017 04:09 PM
viciousv
02-15-2013 10:48 PM
tware4021
01-30-2010 05:40 PM
Big_Carp
05-17-2008 12:33 AM
Quick Reply: Smoke around the driver side headlight
