Smells like burning oil!
Old 05-09-2009, 02:48 AM
audi760's Avatar
Default Smells like burning oil!
Hey people hows it going?
Well i have a 04 a4 1.8 and i had this problem before where when i drove the car it would start to smell like burning oil. I had just gotten the oil changed so i figured they had spilt alilttle. Well this went on for months so i took it in to the dealership. My cam adjuster seal???? was leaking. so they fixed it but now a few days later it still smells? whats wrong with my car
Old 05-10-2009, 09:28 PM
pa4ul's Avatar
valve cover gasket possible. Can u see moreorless where the oil is leaking. Is it near the rear ontop of the cat?
Old 05-10-2009, 09:44 PM
shane.trammell's Avatar
my three way breather is cracked and it smells like that. Look under your intake manifold for dried oil.
Old 05-12-2009, 01:26 AM
nyone8t's Avatar
Yeah I have the same issue as shane and sometimes when I stop at a redlight I get a burnt oil smell. Check all the rubber pieces on the pcv system youll probably find a cracked or ripped hose.
Old 05-13-2009, 10:32 PM
audi760's Avatar
it was the cam adjuster seal
Old 05-15-2009, 11:01 AM
pa4ul's Avatar
yea ive had that replaced how much they charge u for it?
Old 05-15-2009, 11:12 AM
Cas1985's Avatar
just curious, did you recently have your timing belt changed? i remember someone else on this forum changed their own belt and installed the cam seal wrong and it caused the same problem as you. then they went back and fixed the install and problem solved.
Old 05-15-2009, 01:31 PM
audi760's Avatar
nope i havent changed my timing belt and luckily my car is still under warranty so it cost 50 dollars
Old 05-18-2009, 10:16 PM
darowdyestazn's Avatar
is the 3 way breather a hose?... i have a rubber hose thats connected 3 way n its cracked to hell..i have no idea wat it is but looks like oil is comming out very lil but its a big crack.its oh the engine toward the firewall kinda under the manifold?..and im losing noticebily...and where can i get the part?.
Old 05-19-2009, 11:45 AM
that sounds like the 3 way breather. You can get them from ecs, or the dealer might be pretty cheap.
Quick Reply: Smells like burning oil!
