Rough Idle, Underpowered 1.8T
![Default](https://www.audiforums.com/forum/images/icons/icon1.gif)
I have a 03 audi quattro 1.8t
and it feels underpowered and idles rough, but at all other rpms it's fine. no problems minus the being underpowered part. i'm talking 0-60 in about a minute. Flooring it at 70 and not going. I don't think it's the turbo is out because i can hear it spool down when i shut the car off.
how many miles? and have you done mantinence it could be one big thing or just a bunch of little things oil change trans oil change air filter mabye fuel filter mabye even try seafoaming the car i just did mine put some in the gas tank and into the intake it actually worked lol post more info.
Fixed what i hope to be the whole problem if not. 90% of it. MAF sensor was bad. unplugged it no more lights. but the code still throws tps sensor, and maf. so hopefully those two will clear it up. I'm also changing the oil and everything tomorrow as well. Just bought the car.
replaced maf sensor. and found a crack in a vaccum hose elbow. fixed those two. still idling rough. not as bad. but still idling rough.
The codes i'm throwing are.
Random misfire
Cylinder 1 misfire
Cylinder 2 misfire
Changed spark plugs, and oil, and valve cover gasket today. Spark plugs were kinda white on the tip. Making me think it was running lean. It threw the code when i was doing about 45 accelerating hard. So i'm venturing to guess fuel system related.
Fuel pump or filter? or both? maybe fuel pressure regulator?
Also where is the check valve in the fuel line?
Random misfire
Cylinder 1 misfire
Cylinder 2 misfire
is your car still running rough idle? most of the time when its coil packs the mil will start to flash. have u gotten a diagram of the vac lines and gone through each of them to make sure their isnt any visible cracks or anything.
well after doing the handy dandy vacuum boost test technique on a4mods.com i found that there were no leaks in the vacuum system. but in order to do this properly your supposed to remove the pcv valve out of the equation. therefore with it being the last vacuum issue. i cleaned it off and attempted to blow through both holes. and i was successful. thus meaning. bad pcv valve. started the car with it pinched off. ran just fine..... talk about a PITA.
I'm going to return the coil packs i bought because i thought that might also be the problem. Well my brother kept aruging with me that it was for hours and hours.
Problem solved. Going to do the vacuum /check valve removal/simplification thing on audizine.
