Quart oil overfil on 1.8T Engine
Quart oil overfil on 1 8T Engine
I had a check engine light on once, I Disconnected the batt for about 10 min and it was gone, if not I think a autozone or something to that effect can do it for free... Let me know if you need to know how to reset the oil sevice thingy
Here's the problem you are worried about:
If enough oil is added above the full mark to cause the bottom of the crankshaft to be in the oil, then it will be beaten to a foamy froth and the added air in the oil will not lubricate properly, could cause engine damage.
The question is "How far above the full mark on the dipstick is the bottom of the crankshaft?"
I don't know the answer to that, but I bet your local Audi service does (or can get it for you).
Another problem with too much oil is the change in oil pressure at the turbo. This can cause seals to start leaking prematurely.
I'm sorry but are you in the wrong thread young man?
Dude.. I answered in your other thread... over filling the oil is BAD. What Lyman told you is exactly right. And, while the amount of overfill varies before the crank is in the oil, just having it closer is very bad due to a thing called 'windage'. Google is your friend if you wanna look it up.
The engine drives absolutely fine as it did when i had the extra in there.. I guess I'll never know.. I was down at the Audi service today and even just asked them and told them what happened omitting the 1500 miles driven. They didn't seem to know either on how much is too much.
Perhaps i slightly reduced the life of the engine? If any damage was done I probably wouldn't know till later on.. So for now I'm just going to get over it.
