P1556 - I am confused after doing some reading
Old 06-15-2009 | 02:16 AM
SrK's Avatar
SrK
Default P1556 - I am confused after doing some reading
I have done some search about this code but I am confused since the problem I have can't really be explained with the results I found...
First off. I have a 2002 Audi A4 1.8t CVT (chipped APR) 127K miles
I have recently changed spark plugs and coils (7K ago)
Today in the morning I went out for errands no problem came back... but an hour later when I tried to start the car It cranked but didn't start. Tried couple of times and it started but idled very rough so I killed the engine. (no lights in the dash)
I pulled the following codes.
VIN: Mileage: 203750km/126604miles
3 Faults Found:
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 004 - No Signal/Communication - Intermittent
17964 - Charge Pressure Control: Negative Deviation
P1556 - 002 - Lower Limit Exceeded - Intermittent
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 002 - Lower Limit Exceeded
Readiness: 0000 0000
I cleared the codes and it started right up and did not have another problem.
Now from what I read it looks like the P1556 points to waste gate valve ( I already have the new version installed) . But it doesn't explain the not starting or running rough at idle.
I have read on the VW forum that it could be the MAF but in the Audi forum nobody mentions that...
Any help?
Thanks
Serkan
Last edited by SrK; 06-17-2009 at 02:47 AM. Reason: lets shorten it a bit, maybe it is too much reading...
Old 06-15-2009 | 02:35 AM
SrK's Avatar
SrK
BTW I can't find any information about the P1556 in the Bentley manual. Do you have any idea why?
Old 06-15-2009 | 09:42 PM
SrK's Avatar
SrK
Anybody?
mmarwaha
03-29-2018 11:38 AM
dark knight
05-09-2009 02:20 AM
JettaRedII
06-22-2007 10:27 AM
milhouse
06-11-2006 01:08 PM
Wagnerlgv
05-22-2005 04:44 PM
