Oil overfill & Oil Pressure warning
Old 11-06-2013 | 08:57 AM
colinst205wrc's Avatar
Default Oil overfill & Oil Pressure warning
Hi all, looking for some help please.
I have a 2.0L TDI 2005 so think its a B6. The engine code is BLB so hope this helps.
I noticed a couple of days ago the engine seemed noisy on start up in the morning. Once warm it was fine. So I checked the oil and it was down to the minimum on the dipstick. I got a 1L of oil and put it in. I didn't think that 1L would take it from min to overfilled so didn't check just drove home. as it was late on Sunday evening the roads were empty and the car was fine. The following morning after driving for just a min or two the oil pressure light came on. This came on a couple of times and went off and once I reached the motorway all was fine and didn't come on again. On the way home this was repeated. Once home I checked the levels and the oil was past the max. It was up to the flat bit of the dipstick past the bobbles so I think this is overfilled. I took the car today to get an oil change as it was due in 1500 miles and I still have the same issue.
I have noticed if I keep the revs above 1800-2000 then I have no issues. Once below about 1800 the oil pressure warning comes on. The car starts, idles and accelerates fine. The turbo spins up fine and I have suffered no loss of power at all.
Having read a lot of info now about the oil pump being chain driven and this causing issues I don't know what to try next. It seems it all started when I added the extra litre of oil.
The car is at 143k and I have the oil change done regularly and the car hasn't skipped a beat in the year I have owned it.
What peoples thoughts?
Thanks in advance for your help.
Colin
Old 11-19-2013 | 07:30 AM
jtblue's Avatar
You haven't really overfilled the oil so I don't think that's the cause of your problem. Try checking your oil pressure and if its within spec it could be a faulty oil pressure switch.
Knkse5
09-12-2013 08:43 AM
Amazo
B7 Models
03-30-2013 01:40 PM
demmichael
03-25-2013 03:30 PM
jdlyne
12-09-2012 08:52 PM
mekyjesy
11-10-2011 09:23 AM
