Need some help/input. Service code P0411?
Old 08-24-2010 | 04:38 PM
tapA4's Avatar
Default Need some help/input. Service code P0411?
Hi all, I got a 2003 A4 about a month ago; took it to the dealer and had them look at the check engine light, I ended up needing to replace a bunch of vacuum hoses and my solenoid valve. I've replaced all of the bad vacuum hoses and replaced the solenoid valve, and in the process of doing so I also put in a K&N air filter. With all of that done, the check engine light went away and haven't had it come back on............until yesterday. I took it and got the codes read at Advance Auto and the code that came up was "P0411 Secondary air injection incorrect flow". I've found that it may be my purge valve from talking to other people, but I'm still not certain. Can anyone give me any input or advise me on what it could be and what I can do to get it "fixed".
Many thanks!
Old 08-24-2010 | 05:59 PM
xiaokai's Avatar
Hey
maybe i dont have an answer for u but i did a search and found this
https://www.audiforums.com/forum/general-tech-50/p0411-solved-90619/
let me know if its of any use
p.s.
after looking at this link
it seems the problem if the hose is still there
http://www.alldatadiy.com/techtips/A.../20090630.html
Old 08-24-2010 | 06:19 PM
pa4ul's Avatar
just do a check on ur check valves and vac lines. LIsten for hissing or brittle hoses. Maybe the tech forgot to replace on of the lines and it faulted later. Normal problem with out cars.
Old 08-24-2010 | 11:04 PM
tapA4's Avatar
Originally Posted by xiaokai
Hey
https://www.audiforums.com/forum/showthread.php?t=90619
p.s.
Alright! Thanks for the assist! I'm gonna do the hairspray trick too to check for leaks. But just to make sure I'm understanding the other forum post correctly (p0411 solved), could you attempt to explain to me where the combi valve is located at and where the secondary air pump is at? I know where the purge valve is, and where the air box is (obviously lol) but just so that I can try to make sure I've got my bearings straight when I get in there tomorrow.
Thanks again!
Old 08-25-2010 | 01:02 PM
pa4ul's Avatar
Old 08-25-2010 | 02:48 PM
tapA4's Avatar
Thanks! That will help me solve a bunch of issues! Also, on this link here: http://www.audizine.com/forum/showth...hlight=in-line
do you think that the valve labeled 1 could be the issue? if not all of the valves?
Old 08-26-2010 | 04:48 PM
pa4ul's Avatar
if u rub it with ur fingers and feel stuff peeling off then its probably in need of being replaced. Those things go bad often.
Old 08-27-2010 | 01:30 PM
tapA4's Avatar
Alright, I'll go back and check that as well. Thanks for the help man!
knowledge 101
07-03-2012 04:55 PM
knowledge 101
01-07-2010 08:59 PM
A4 2000
08-28-2009 01:28 AM
99-A4
06-10-2009 09:26 PM
intake
03-21-2008 07:58 PM
