MY A/C SMELLS BAD.....
when I turn it on. It only lasts for like 30 sec. but the smell is horrid. Do I need a new air cabin filter or is it something else? And I feel like it takes too long to get cold. WHat do I need to resolve that? Thanks
RE: MY A/C SMELLS BAD.....
What does it smell like? You need to start taking stuff apart.
Stagnant water: I have found 2 general causes to bad odors in the HVAC systems on cars. Not Audi specific but there isa drain to allow condensation water to exit. If the drain plugs up the water gets stagnant. Sometimes you can get at this from under the car, i.e. stick something up the drain tube to see if you can unplug it, you might get lucky.
Dead animal: The other cause is a mouse getting into your vent system, if they can get in the air intake they generally die in there. I had to pull a whole dash apart in a t-bird once to get a mouse out. Nasty job.
Added note: Yes the cabin air filter can get bad, It's easy to change out too. But it shouldn't cause a really bad smell.
