Multitronic - problems
![Default](https://www.audiforums.com/forum/images/icons/icon1.gif)
Hello,
Audi A4 B6 2.5TDI (bfc), 2003MY, 107000miles.
The first problem was with ECU as Vagcom showed two codes: 17134, 18149.
The ECU is now fixed and codes did not return again but is still the same problem as previously. When I select P or N and put my foot down the revs goes max. to 1200rpm. Second problem is that when I select D or R the car does not move on his own, I have to put my foot down and then it revs. to 1500rpm and then moves forward and after 2sec. stops, so is impossible to go quicker than 5mph![Frown](https://www.audiforums.com/forum/images/smilies/frown.gif)
The gearbox is filled with new special oil for multitronics (4.6L). My service book shows that the previous owner has changed body valve unit at 50000miles and I am not the first person who touched ECU because date on ECU is 2007. When Audi's front wheels are lifted and I select D then it makes horrible noise and engine shakes and you can hear clicks( click,click,click and so on). I havent seen similar problem on the forum. Can any one help me
? Also I have all details from Vagcom (Voltage, Temp, speed, Current etc of 25groups)
Thank you
![Big Grin](https://www.audiforums.com/forum/images/smilies/biggrin.gif)
Thank you
![Wink](https://www.audiforums.com/forum/images/smilies/wink.gif)
