Intermittent Start/Stall problem
Before anyone brings it up, I did search extensively, but didnt find anything matching my exact problem.
2003 A4 1.8t Quattro 5spd
I just bought the car and didnt even have the problem happen to me until my wife mentioned it.
Intermittently immediately after starting, the car stalls. Its a manual trans and I have the car in neutral with the clutch pushed in. Once I start it again its fine. Like I said, it completely starts, and runs at about 1000rpm and then it immediately drop to 0. Its not like its just not starting at all. The engine is definitely running for a second or two.
i also have this intermitten problem... same scenario manual trans in neutral starts fine after stall with the rpms just dropping from 1 grand to 0. if you find anything out let me know. i myself have been looking into this problem also.
well I really have no experience with German cars, but if I was diagnosing a GM the first thing Id suspect is the fuel pump. I plan on doing some power upgrades soon, so maybe I'll just replace the fuel filter and upgrade to a walbro 255 and see what happens.
I would start with that. Check the pressure at the fuel rail by depressing the schraeder valve on the firewall end with the ignition switched on. There should be a pretty good spray. If there isn't much pressure it's either a bad filter or the fuel pump. There are write ups on the filter and the pump either at audidiy.com or possibly on audizine.
