Injectors Not Firing.. PLEASE HELP
my car wouldnt crank and my fuel rail wouldnt pressurize. i sent my ecu back to oliver at speedtuning to reload the software. i got it back today, and my fuel rail is now pressured up, but the car wouldnt crank at all. it turned out to be bad relays under the ECU. i swapped em out with another 1.8t. and now my car cranks. no fire. fuel rail is pressurized..... the coils are sparking. new plugs. gapped to.028. perfect.... we sprayed starting fluid and it at least fired and ran for a second. so... now i donno whats wrong. my injectors are not firing. but i pulled the main fuel line and turned over the car... it is pushing PLENTY of fuel. but none is getting to the plugs. Is there another relay i could replace. like for the injectors? all fuses are ok.... my car is sparking and pushing fuel. just the injectors arent firing. none is getting the the plug bays. HELP
xxipsxx
12-11-2010 03:13 PM
MC Hammered
02-04-2008 12:06 AM
