Idle surges about 300 RPMs up and down while moving.
This is a 2002 Audi A4 1.8T Auto.
The car idles fine even when the transmission is enganged, howerver, when I start moving the car shakes a bit and when the transmission changes gear it shakes again.
I also noticed that once the car is moving the RPM go up and down in a range of about 300 RPMs, during this time the car holds back and then continues.
As you can see this sounds like two different problems, I look forward to read ideas about these two problems.
Thanks in advance.
Thanks in advance.
There was one code, misfire cylinder 3.
This is because the coil on cylinder 3 was not working at all, the coil was replaced and the code cleared.
shane excuse my ignorance, what is the snub mount?
You can can feel it and if you look at the tach you will see the needle jumping up and down.
