Idle drop after coming to a stop
I wouldn't get a CEL for a vacuum leak necessarily, would I?
hey whatsup protein! i know i have b5.. but i had same problem. it was sludge build up. check your throttle body and connection. had to clean it out. there was tiny build ups that caused NO air to get through when idling. this causes the engine to "choke" because it has no air.
Just my suggestion because it worked for me
Yes you can get a CEL from a vaccum leak, if not i can tell you if you have a vaccum leak from data block 32 in the ECM.
Other than that Lawnferie hit the nail on the head, 1.8T engines commonly get carbon build up on the throttle body valve which can cause an excessing amount of air entering the engine at idle messing with the engine management.
