How To Run with Fogs Only
Ok,... I know this has been posted over and over... I Vag-com 'd my car and changed the settings to all the possible country codes. It was already set to the all other countries code... when i changed it to USA, Canada, or the other countries it made my headlights stay on w/out the **** being turned... ??? any ideas???
thanks
thanks
RE: How To Run with Fogs Only
thats exactly what the Canadian country code does. Unless you have an 02 A4 you need to rewire your headlight switch for independent fogs. Otherwise you have to settle for sidemarkers and fogs all the time.
your side markers will always be on when the fogs are on. Even on mine the side markers are on. Luckily though, the ecodes re-route the side markers to the city bulbs so it looks good instead of having the orange lights.
^^^ What he said. And, the >'03 wire splice is a simple 5 minute operation that is easily reversable. There is a how-to on either AZ or AW.
But also as mentioned, you've got side markers no matter what unless you completely re-wire the things. But fogs without headlights works well, especially with clear corners or ecodes with city lights.
