How do you remove a door handle?
Old 07-29-2008 | 11:16 PM
swirly's Avatar
Default How do you remove a door handle?
My 2002 1.8T Avant will not lock with the key, but the locking system works fine with the fob. I pulled the door panel and found that there is a little torsion rod that connects the cylinder with the actuator. There is a little paddle at the end of the rod that fits into a slot on the actuator. Mine is not connected, likely the result of some collision work I had done a long time ago. Anyway, there is not enough clearence to bend the rod into the slot. The only way I can see that it would work would be to remove the outside door handle. Anyone done this? Thanks.
audi guru
06-06-2013 05:39 PM
bauer1185
04-30-2009 04:02 PM
baconkid92
02-18-2009 05:07 PM
blks4
03-29-2007 08:02 AM
auDi1.8TQ
04-28-2005 01:25 PM
