How do I remove the rims' center cap?
Old 06-19-2010 | 01:30 PM
Prizmatik's Avatar
Question How do I remove the rims' center cap?
I have owned my B6 for 4 months now, and its time to rotate the tires. I cant quite figure out how to remove the center caps without breaking them. Any help is appreciated.
Attached Thumbnails How do I remove the rims' center cap?-audi-parts-018.jpg   How do I remove the rims' center cap?-audi-parts-019.jpg
Old 06-19-2010 | 03:46 PM
Soravia's Avatar
Hmm.. mine is different but maybe you can turn it counter clock wise too?
Old 06-19-2010 | 04:36 PM
Prizmatik's Avatar
Thanks for the help, but it didnt work. I tried looking in the hole and have tried using a phillips screw driver and allen wrenches, but just doesnt feel like there is a screw in there. So maybe it needs to be pryed out, but I dont want to try in fear of breaking the center cap.
Old 06-19-2010 | 04:50 PM
Soravia's Avatar
Discount tire guys tried to pry out mine and damaged one center cap. I don't think they are supposed to be pried out if there are no notches to do that.
Why not stop by an Audi/VW service center. I'm sure they can find instructions at least.
Old 06-19-2010 | 08:21 PM
olstyn's Avatar
There should be a little toolbox in the trunk to the left of the spare. There's a thing in there that looks like a thick piece of wire with a loop on one end and a bend at the other. Stick the bent end in the little hole on the center cap, put your finger in the loop, and pull. The cap should come right off. It requires a little force, but nothing major.
Old 06-22-2010 | 01:36 PM
Prizmatik's Avatar
Thanks a lot Olstyn. You hit the nail on the head. Now I can rotate my tires.
Old 06-23-2010 | 11:05 AM
olstyn's Avatar
Happy to help. Now I just wish I could figure out what's causing the metal on metal clanking noise mine is making when I drive on a bumpy road! Ah well, I suppose I'll probably have to take it to somebody to get it looked at.
Old 01-03-2015 | 10:46 AM
LindaLu's Avatar
Default metal on metal clank
Anyone ever find out what the metal on metal clanking noise is when going over a bump? (From an old post I just read). Have same issue, took car to Audi and others....LOTs of repair$ made!!!! Noise still there....
Old 03-02-2016 | 10:48 AM
ASULIKEIT's Avatar
The centre caps are a strait push fit. Insert an L shaped tool, like a small allen key into the hole and pull hard with mole grips. The plastic cover will come strait out. Its a push fit to re insert.
Zachariah
09-27-2010 12:01 AM
Munzter
07-22-2009 08:16 PM
andrewbb89
12-09-2006 09:17 PM
zebinheimer
11-26-2006 02:17 PM
S4sweeteeteeRS
04-06-2005 04:15 PM
Quick Reply: How do I remove the rims' center cap?
