how to adjust front windows...
installed new regulator, window goes up and drops a few inches...eBahn manual says to lift switch to max height, hold 2 seconds and release...it is suppose to set the high-low positions...mine is not working this way...
any ideas?
Thanks
any ideas?
Thanks
thanks...tried that first but didn't work. It goes up to top, drops 3 ", will go all the way down. If I repeat a few times will not work at all unless I leave it sit. Must be some pressure protection (child) switch...still trying to get it to work.
Note: I do not recommend aftermarket window regulators as the bracket/pin which fits into the window bracket (black piece) is not ribbed and is much more difficult to adjust/hold.
More ideas appreciated.
Have you tried disconnecting the battery for a couple minutes, and trying again? If it still isn't working, the fact that you used an aftermarket regulator could be your problem. Where did you purchase the regulator?
Ok, so if the windows work but it rolls down at the top, then the regulator is probably causing pressure, that's what would normally happen when something gets stuck on the window. I don't know if you utilized an original replacement part or not, but I do know that there was one of those e-bay regulators giving some problems like this.
Purchased from Dart Auto in Colorado; Porsche/Audi shop & parts...$122, not OEM. It originally worked fine until the bracket part attached to the window came loose; I glued and reinstalled...I noticed that they now advertise the window regulator (probably a different one for $45); I plan on giving them a call...
