headlight moisture
With my setup i drilled a hole through those covers and put a weather proofing on either side which came with the hid kit
The H.I.D's are not sealed - they are vented to the atmosphere by design. One cause for excessive fogging is faulty o-rings. There's a DIY on fixing this at http://forums.audiworld.com/a4gen2/msgs/893818.phtml. I'll be trying this one before the fall rains arrive.
#20
Here's some additional points beyond what's in the DIY:
- The replacement o-rings you'll want to get are size #78. I bought a pack of 10 at Home Depot for under $2
- The trick when filing down the existing adjuster shaft is to widen the channel that the o-ring sits in, but keep it's factory depth. I had a 1/8" round file (used for sharpening chainsaw blades) that worked perfectly.
- The headlight adjusters should still be operational once you are done. I tested mine and they still worked - make sure you lube around the o-ring.
That's it!
