Having problems with my cabriolet
Old 05-22-2012 | 03:44 PM
m.c.'s Avatar
Default Having problems with my cabriolet
2002, 2.4 v6 Petrol, B6 Cab.
With it being a nice day today i decided to drop the roof for my drive home at dinner time, got out, opened the boot to get somthing out, locked the car, no probs.
Went out to go back to work and the door wouldn,t open (unlock or lock) with the fob, the electric windows and mirror,s will not operate, the roof will not close (had to close manualy), no indicaters or reversing lights and fog lights, electric seats won,t work.
I have a smart roof mod fitted aswell, if that is of any use.
Did a scan and these are the faults that came up, i know about the Air injection system bank 1 and 2.
Any help with this would be great.
6 Faults Found:
17947 - Clutch Pedal Switch (F36)
P1539 - 004 - Implausible Signal - Intermittent
17831 - Secondary Air Injection System; Bank 1
P1423 - 002 - Insufficient Flow - Intermittent
17819 - Secondary Air Injection System; Bank 2
P1411 - 002 - Insufficient Flow - Intermittent
18010 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 008 - - Intermittent
18043 - Powertrain Data Bus
P1635 - 008 - Missing Message from A/C Controller
Readiness: 0000 0000
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Component: Innenraumueberw. 0211
Coding: 00001
Shop #: WSC 00000
No fault code found.
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 186
Component: concert II GRO 0008
3 Faults Found:
01300 - Control Module for Navigation with CD-Rom (J401)
49-10 - No Communications - Intermittent
01317 - Control Module in Instrument Cluster (J285)
00466 - Control Module for Steering Column Electronics (J527)
End ---------------------------------------------------------------------
Old 05-22-2012 | 08:03 PM
Audi Tek's Avatar
Tech Certified
The loss of communication with the cluster, the immobilizer is in there. Figuring out why is another thing all together
Old 08-14-2017 | 08:34 PM
spenni1's Avatar
sounds like you need a new comfort control module. Same thing happened to my car they are located under the driver's seat rug.
gamocles
05-02-2017 04:53 PM
dogasawara
11-13-2012 04:49 PM
starsshine4us
10-12-2006 04:23 AM
thejobcoach
09-16-2006 04:24 PM
mrlancer
08-19-2005 07:51 PM
