Front brake pad change
Pretty much as the title says. I cant figure out how to get the front caliper off to change the pads. any help is appreciated. I cant afford to get the bentley manual right now so im hoping someone here can help.
thanks in adavance guys
jeff
jeff
This instruction is for B5, but should be the same for B6.
http://www.audizine.com/forum/showthread.php?t=189128
good call thanks for the heads up. does anybody have any tips for getting them off. its a little cramped under there so i cant get the air ratchet under there. ive tried some penetrating oil but no luck. also, whats the best way to jack the car up because i know there are specific jack points but i dont trust that audi tire jack.
Not to seem like an ***, but are you turning the right way? You are working backwards, so never know.
I wouldn't use the air ratchet, just a good wrench, maybe a breaker bar, and your hands. Its way to easy to screw things up with an air tool.
I jack up using a floor jack at the same points.
brrman
04-16-2009 05:26 PM
