forge splitter
Old 11-19-2008, 04:06 PM
SunnyShaida's Avatar
Default forge splitter
I'm thinking about getting a forge splitter because I want that blow off valve sound but still recirculation of air, what do you guys think? Any opinions on it or precautions? And I read somethin about not being able to use the same engine cover?
Old 11-19-2008, 04:20 PM
Jc61990's Avatar
i have a splitter on my B5, idk how different the B6 engine is, but the valve is under the engine by the turbo outlet to the radiator. i dont see how it could prevent you from using the engine cover...
Old 11-19-2008, 04:28 PM
ya neither do I but I was looking at one on eBay and it said
I can't use the same engine cover due to heat in the description of the item so I was wondering what that was about
Old 11-19-2008, 09:46 PM
Jc61990's Avatar
seriously... heat?, theres no difference from a regular DV other than it has a horn on it... who ever is selling it, is really retarted.. you should buy it from a retailer.. i got mine for only 160 at http://www.namotorsports.net/detail....t_cd/FMDVSPLTR
Old 11-19-2008, 09:48 PM
Jc61990's Avatar
oh and i think i see what your saying, but it pertains to a B5 S4. cause the DV's are on the top of the motor
""These valves will work on the B5 S4, however, you will not be able to use your stock engine cover once they are installed due to the height of these valves.""
Old 11-19-2008, 09:52 PM
audiprotein's Avatar
you would be fine with 1.8 motor
Old 11-19-2008, 10:48 PM
ohh that makes sense...cool
Old 11-20-2008, 11:08 AM
kwik_shift's Avatar
Once you pick it up, it would be a good idea to service it every other oil change.
Old 11-20-2008, 11:52 AM
what kinda service?
Old 11-20-2008, 04:00 PM
Grease the inside the valve (spring)
Quick Reply: forge splitter
