Fault codes - possible intake leak
116622/P0238/000568 - Manifold Pressure/Boost Sensor (G31): Signal too High
16490/P0106/000262 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
16712/P0328/000808 - Knock Sensor 1 (G61): Signal too High
These are my codes, I have noticed a boost about 5psi low and vacuum a few Hg off too, and when I turn on my AC the vacuum gets worse. No check engine light though. I tried testing for a boost leak, and heard a hiss but on the front left of the motor but could not locate it precisely. I cranked the car with with no MAF to test it and it ran ultra rough, and I turned off imediatly. any help
3 weeks ago i replaced a knock sensor, but havent had any codes from it since.
RE: Fault codes - possible intake leak
Found an intake line that was loose, had no clamp, I put one on it, cleared codes and drove yesterday. No more code, but my vacuum is still wonky when i put my ac on full blast. (14-15hg) and boost pressure hits goes to 18 not 20 like normal and doesnt really hold, seems like it is spooling slow. I need to get the system smoked to find the leaks. I feel like its leaking, and I have this honk after releasing accelerator, I thought it was my dv, but it still happened after I replaced it with a apr r1 dv.
