ECS Timing Belt kit with lightweight crank pulley.. Worth it?
Hey so I'm looking into ordering my timing belt kit due to the need to replace it all. I am looking at the ECS Tuning kits they have. I was wondering if there is noticable gains if you were to get the lightweight crank pulley they have in the higher kit? I have pretty much a stock 1.8tQ... Its about 120 bucks more so if its not very noticable I probably won't get it... Any advice?!...
I would stay away from this. ECS R&D is no where near where I think it should be IMO. Think of the crankshaft as a balancing act. It is almost equal on both sides, the stock crank pulley and the flywheel...I assume would weight the same (if not, then the engine was designed around the weight difference). By subtracting weight from either end would throw off the balance of the crankshaft. Think of a see-saw. I would assume the lightened crank pulley would work best accompanied with a lightweight flywheel. However heavy flywheels are good for tiny engines like ours because without it they would simply stall out when put under heavy or repetitious loads (for instance, climbing a hill, burnouts, or even stop-and-go traffic). Simply for the power gains of the LW crank pulley, not worth it.
Alright that makes sense. Thanks kwik shift! I just thought it would be an easy mod. I can't really afford other mods at the moment so I thought if I could sneak one in there why not! But that makes sense thanks!
ECS Tuning
11-08-2013 03:47 PM
