Drivers window problem
Hi All again,
Another issue I have recently have is with the electric window on the drivers side...
Last week it started to make a strange sound as if something was scratching the glass as I lowered and raised the window, it quickly got worse and now the window doesn't always go down or up (It takes several attempts to get it back up).
After doing some reading, it looks like the regulator is shot... but this also looks expensive to get replaced.
Is it still worth me whipping of the door panel (looks fairly easy) and having a look ? Is it likely that something just needs popping back into place, or dirt/grit has got into the system ??
Just a thought, I am guessing someone else has experienced this out there....
Thanks all !!
Adam
Thanks all !!
Adam
All you
Take a look at the following link
http://www.audiworld.com/tech/int45.shtml
I fixed my A6 front windows a few months ago following that advice. No more problems.
Good luck!
Good luck!
