dome light
dome light
I dont know if this is happening to anybady else but i just figure out that when i open my right passenger door the dome light wont come and and lights around the door don't work ether. Also when you look at the dash to see if any door is open it doesnt show like its open. I did check it the fuses and i do have power in the door ???
Any ideas would help.
thanks.
thanks.
No those are the only lights that are doing that, but i did find out what the problem is because i took the door a part. It was the latch that not recognizing the door open or closed. i had to disconnect the wires clean them and put tham back and worked fine after.
jasmix
12-12-2007 09:47 AM
