does anyone have the symphony sound wiring diagram/pinout
as the title says.
or what is the best way to add a subwoofer and amp to this system. i must have the only b6 without the bose, cause all the write ups for the install is for the bose!
im pretty stereo litterate, and would imgine to either hook up to the little subwoofer on the back deck, and do a high pass filter, or find the amp (if its exteral) and hook up to the audio in.
any light on the subject is appreciated.
i bought my self a cragslist steal for x-mas! jl audio w7 10, and the 500/1 amp, for 400 bucks! would like to hook it up over the holiday.
thanks in advance.
thanks in advance.
a4mods.com has a diy. But to me the easiest way to hook up a system to ur car is buy a lowoutput converter at bestbuy/walmart just about anywhere they sell electronics. Then plug that into the rear subwoofer wires in the rear deck. All u gotta do is pull of that grill and then plug up your power ground and rca's and remote u can tap into the fuse box ill check which fuse im using to get remote power. If u need more info or help lemme know.
thanks for the info.
yea i meant to say low pass filter not high! oops.
so thats what ill do, and dont worry about the remote wire, the new jl audio subs has a signal remote feature, so you dont have to hook up a remote if its not avail. as soon as it senses a signal, the amp turns on, and turns off after a specific amount of no signal. neato!
thanks again.
thanks again.
lucky123
04-04-2023 09:55 AM
