DIY Starter
Old 04-24-2008 | 01:43 PM
Remman's Avatar
Default DIY Starter
I have an '04 a4 1.8T. When trying to start it, it was clicking loudly. We jumped it and it started fine. I am hoping it was a one time thing with the battery and there wasn't enough juice for the starter and now everything is okay. But I also read it may be a sign of the starter going bad.
Is it easy to replace? Are there any DIY instructions anywhere? I looked, but with no luck.
Old 04-24-2008 | 02:12 PM
captain's Avatar
Default RE: DIY Starter
Starter is probably ok. Sounds like low battery or dirty/loose connection of the battery cables. Clean them. Your battery may just be shot.
Old 04-24-2008 | 02:16 PM
Remman's Avatar
I think it is the original battery. The connections are clean. It has 80k on it. Is there any special battery needed for Audi's?
Old 04-24-2008 | 02:23 PM
audi4clint's Avatar
I would definitely check the battery first, but if it is the starter these instructions might help. Good luck.
Audi > B6 Platform > 2002 - 2005
Electrical Equipment
27 - Starter
Starter - 1.8L 4-cylinder Turbo engine, removing and installing
Special tools, testers and auxiliary items required
VAG 1331 Torque wrench (or 5 - 50 Nm equivalent)
VAG 1332 Torque wrench (or 40 - 200 Nm equivalent)
Starter - 1.8L 4-cylinder Turbo engine, removing and installing Page 1 of 3
Removing
Disconnect battery
Battery in engine compartment, disconnecting and reconnecting .
Lift vehicle.
Release fasteners -
1 - and - 2 - and remove front noise insulation.
Remove nut at starter solenoid terminal B+ -
2 - and remove connector eyelet from
terminal.
Disconnect electrical connection for terminal 50 -
1 - .
Remove insulator from positive connection on starter where applicable.
Remove harness clamp -
4 - .
Remove bolt -
3 - from engine block to starter bracket, and remove bracket.
Starter - 1.8L 4-cylinder Turbo engine, removing and installing Page 2 of 3
Remove bolts -
1 - and - 2 - .
Remove starter from below.
Installing
Install in reverse order of removal, noting the following:
Reconnect battery. Required steps .
Tightening torques
Component - fastener Nm
M10 45
Starter to transmission bracket - bolt M12 65
Terminal B+ to starter - nut 16
Dallas09
09-27-2010 10:48 PM
Pat W
09-20-2010 09:03 PM
im so audi5000
05-02-2009 11:23 PM
Dr!ven
06-21-2006 05:50 PM
auDi1.8TQ
02-22-2006 03:07 AM
Quick Reply: DIY Starter
