Crankshaft position sensor confusion
Old 08-19-2010 | 12:32 AM
Piperalpha's Avatar
Default Crankshaft position sensor confusion
Hi All,
I have a A4 3.0 2002 and have the "P0322 Ignition\Distributer Engine speed input circuit no signal" error reported.
I've been looking around the forum and it seems that this is a crankshaft position sensor malfunction (Engine speed sensor).
It seems simple enough but would I be correct in thinking:
1) The 1.8 version of the car has 1 crankshaft position sensor, located by the oil filter?
2) The 3.0 version of the car has 2 crankshaft positions sensors - 1 at the back of the engine near the drivers position and 1 under the timing belt cover at the front of the engine?
If I am correct in point 2) - which one should I swap out with a P0322 code?
Any help is appriciated...
BTW car keeps shutting off and is difficult to start and also the EPC and CEL are on.
Cheers
Piper Alpha
Old 08-19-2010 | 12:41 AM
02rubya4's Avatar
i did some quick research and found this out for you
http://forums.audiworld.com/showthread.php?t=2754586
seems as though there is only one and it is located at the back of the engine
also you are correct with point number 1
Old 08-19-2010 | 12:46 AM
Piperalpha's Avatar
Thanks for that - i did see that post but other ones were confusing me as they were talking about that position and also one under the timing belt cover.
I think I will try the one under the heat shield at the back as you suggest.
Appriciated,
Cheer
piperalpha
mikestt
11-29-2012 06:12 PM
vpinargote
09-10-2011 11:53 PM
JPizano23
06-16-2011 08:25 PM
Hotdog
03-19-2010 12:50 PM
mcinp
01-03-2008 10:49 AM
