correct tire pressure
![Default](https://www.audiforums.com/forum/images/icons/icon1.gif)
hey guys. just bought a 2005 1.8t quattro. she'sbeautiful!!!
i was checking the tire pressure on all 4's just to be sure they were all even. i noticed that the psi on them are at "25". seems low or is this howthis particular brand prefers them to be?
my tires are: goodyear eagle rs-a 235/45r17
i read somewhere that audi recommends psi's to be "35".
so can someone tell mewhatare the correct psi's?!
also, whatbrand tiredo the majority of you guys put on your a4's?i wasnt reading too many good reviews on those eagle rs-a's
thanks.
thanks.
It really depends on the tire. A lot of tires will post the recommended PSI right ont he tire. I do believe for that size tire it is about 35 like you said.
And I dont really like EAGLE tires. I prefer Falken or Perelli
If you really want, cruise down to EVENS TIRE or any other tire shop and they can give you a 100% correct answer
Look inside your drivers door, you should see recommended tire pressure. On my 03 Quattro it is 30 for just the driver, if you load the car it varies from 39 to 41 depending on tire rating. 30 is soft and will give you a better ride with acceptable edge wear at some loss of gas mileage, something like 35 or 36 will give you a hard ride with better gas mileage, tire wear should be pretty even. If you load the car a lot you would want to go higher. Check pressure when the tire is hot, i.e. after a drive.
ORIGINAL: captain
NOT AFTER you drive until tire's warmed up!!
ORIGINAL: monkey323i
NO! always check your pressure when tire is COLD!!!!
ORIGINAL: captain
ORIGINAL: jamesfreeman86
