Coolant temp sensor location?
Old 08-14-2012 | 12:26 PM
Audidoo's Avatar
Default Coolant temp sensor location?
New owner of 2002 a4 b6 3.0. Bought two new temp sensors 4 pin (green) fitted succesfully. I can't find the location of the 2 pin (grey). Can anybody help with this. Thanks
Old 08-14-2012 | 05:25 PM
Dozanti's Avatar
correct me if Im wrong someone but on the 1.8 its on the bottom side of the bottom radiator hose on the driver side. Possible it could be in the same area for the 3.0
Old 08-15-2012 | 05:05 PM
Audidoo's Avatar
I think you are right, I managed to find a service diagram which shows it there. Cheers for the input.
Old 08-15-2012 | 07:01 PM
pa4ul's Avatar
just be ready with a bucket when u pop that sensor off.
Old 08-16-2012 | 11:18 AM
Audidoo's Avatar
It isn't on the bottom hose, there is a blanked off plug just above the drain tap but no sign of any wiring. This looks like a factory fitted blank and no sign of any cut wiring. Any more advise please?
Old 08-16-2012 | 05:57 PM
pa4ul's Avatar
Old 08-16-2012 | 06:46 PM
Audidoo's Avatar
Ok, but they forgot about the bleed valve/valves.
Old 08-17-2012 | 01:46 PM
pa4ul's Avatar
u mean the bleeder screw near the manifold?
Old 04-25-2013 | 11:22 AM
99a499's Avatar
have 99 a4 quattro - -mines in the lower radiator hose directly below the air intake passenger side
newvances
11-19-2014 07:06 PM
Chase2008
08-27-2012 03:05 AM
DiscoJaker
10-24-2008 12:11 AM
audiejohn
04-26-2008 11:11 AM
Blueman
01-31-2008 08:25 PM
