Coolant level low after timing belt service
Old 01-24-2010, 08:06 PM
Dan1969's Avatar
Originally Posted by Audi Tek
why was your lower radiator hose removed to do a timing belt in the first place.....?
Someone didn't know what they were doing...
How else would you remove the front end?
  #22
Old 01-24-2010, 08:24 PM
shane.trammell's Avatar
You swing the radiator and support out so you don't have to drain it.
  #23
Old 01-25-2010, 09:12 AM
Dan1969's Avatar
I thought the T-belt job includes the water pump...
  #24
Old 01-25-2010, 09:30 AM
mjfrizz's Avatar
Default timing belt change- tool kit?
I'm considering buying a kit from the below vendor
http://www.blauparts.com/proddetail.asp?prod=GH21133
They have an option to rent a tool kit. Is this necessary? When I look at other posts and sites (like audiworld/tech) they don't mention a kit when changing the belt. Has anyone needed this when changing their belt? Or maybe the kit just has tools that make the job easier, i dunno...thanks
  #25
Old 01-25-2010, 12:03 PM
Midniteoyl's Avatar
It has all the 'special' tools you need (other then basic hand tools).. if you dont have them, you should rent it. Of course, except for the cam/crank locking tools, you should be able to find the rest at you local parts store and rent them for just a deposit.
  #26
Old 01-25-2010, 12:20 PM
3dviz's Avatar
They also replaced my waterpump which might explain why the lower hose was disconnected, maybe to drain? If it doesn't drain like that, than nevermind. But I was wondering, could a leak from a hose connecting to radiator or waterpump cause my headlights to fog up? Ever since the timing belt/water pump, etc. service was done, my headlights have not been dry.
  #27
Old 01-25-2010, 12:27 PM
Midniteoyl's Avatar
Your headlights prolly lost thier seal, and, when the mechanics pulled the lower hose to drain, it was prolly still warm and steamed, fogging the area and getting into the lights.
If you can reach them, pull the bulbs and use a hairdryer to dry them out. Will take time.
  #28
Old 01-25-2010, 01:25 PM
3dviz's Avatar
Man, I am done with this mechanic.
  #29
Old 01-25-2010, 07:45 PM
Dan1969's Avatar
Now don't despair, the foggy headlight might be just a coincidence. It happens to most B6s.
  #30
Old 01-25-2010, 07:54 PM
Midniteoyl's Avatar
Agreed.. it happens.
Quick Reply: Coolant level low after timing belt service
