Coolant level low after timing belt service
The coolant was pink before. I took the car back to him and told him about the coolant being low and he topped it off with Prestone 50/50. If he changed the timing belt, would he have had to flush the system of coolant?
After poking around some more I saw some pink and a little wetness where a hose connects to the radiator near the bottom of the radiator on the driver side. It's at the point where the hose attaches to the radiator, it's sealed all the way around and then on the left side there's a small line of pink visible. I'll post a picture as soon as I get home and hopefully you guys can tell me if this is normal.
As promised, here are the pics of what I think may be a leak from the lower driver side hose connecting to my radiator. Please tell me if you think this is normal or if this is indeed a leak. Unfortunately my something's wrong with my camera and these are the best shots I could get.
#18
Went back to the dealer today, showed him the area of concern, he informed me that it was a seal they put on for lubrication when they attach the hose. I opened my eyes wide with embarrassment. I figured it was leaking coolant because it was always moist there, and it was pink coolant color. But apparently their seal is also pink just like coolant! He showed me the seal they use in its jar. Oh well, I think being overly cautious with my new vehicle is what's gonna keep it goin strong.
The coolant level was still a tad below the min level which I was concerned about so I asked him to add a little. Now I have a new concern. He filled the reservoir tank to the brim, I thought he was just going to fill it up to the max line, and he used a different coolant than he did before. This time he used some coolant that said Mercedes Benz on it instead of the Prestone 50/50 he used before. Do you guys think I should be concerned and rush out to get a flush?
#19
