coolant issue
coolant issue
does anyone know if there is some kinda line that goes from the coolant box to the front right side of the car because i have a leak and i dont know were its coming from. the reason why i think its the coolant is because i keep having to fill it up everyday i checked for a crack but didnt find anythig. i was thinking that it might be a loose hose or something i really dont know i am going to take it to a place called firestone so they can put it on that thing that pickes the car up so they can look at it. i was also thinking that if that is the problem.....that might me the reason why i sometimes see steam come from the front right side of my car. i have seen post about the mystery steam but no one knows were its coming from and what miht be causing it.
RE: coolant issue
i hear its alot to get fixed. upwars of 200$ But they say its a diy. I have the same problem steam coming out of the right side of engine. If u look towards the back of the engine a little to the right and down of the cat converter u might see where the leak is occuring and thats where ur flange is that needs replacing. at least thats where mine is.
RE: coolant issue
yes its the it has something to do wit the cooland, its called COOLANT FLANGE
im sayin it might be the problem but not sure, it is a common thing for audis casue the stupid O ring fails, just look behind the engine and check if the flange is covered wit red stuff
ORIGINAL: silveraudib6
ok but does this piece have anything to do with the coolant at all? cuz i have to keep refilling my coolant everyday
RE: coolant issue
ok heres what happened i took it to a machanic they checked i out and it turns out to be my radiator there charging 600 to replace it. they told me there was some leaking abound the frnt of the radiator on the right. thats were the steam was coming from. so i took it to the dealer and they want 745.50 to replace it. so now my car is just sitting at the dealer because they charge to even look at it. so i dont know if i should let them do it or try to find someone else to get it fixed.
