coolant flush
Old 06-08-2008 | 04:08 PM
blackphoenix's Avatar
Default coolant flush
so, i looked for this red valve everyone talks about to flush out the coolant, i can'tfind it. i took off the front grill vents and searched.. still can't find it.. what is the easiest way to flush out the coolant, or find this valve thingy. thanks
Old 06-08-2008 | 04:39 PM
cincyTT's Avatar
I'm make believe
Default RE: coolant flush
There should be a valve attached to the bottom of the radiator (usually behind and you have to get under the car to find)that you just pull then turn the **** to drain (make sure the filler cap is open also). Then run a couple gallons of distilled water through to help flush any remaining coolant out and then refill with the fresh G12 and more distill water.
Old 06-09-2008 | 11:15 PM
monkey323i's Avatar
If you look through your manual,
it stated audi OEM coolant from factory is permanent, which means does not need to be changed lifetime.
Old 12-31-2009 | 08:12 AM
heywier427's Avatar
good luck with that one...
Cullen
07-14-2012 11:29 PM
Armenian
08-31-2010 05:18 PM
dark knight
05-05-2009 03:12 PM
ConMan
02-16-2009 03:30 PM
mrdb85
10-20-2006 04:26 AM
