Clutch slipping?
Old 09-03-2012, 11:01 PM
Ncbaca's Avatar
Default Clutch slipping?
I have a 2004 a4 Quattro and I was driving on the freeway and my rpm gauge went up but my car had no power. I parked it and now it seems to be fine. I'm worried my clutch is slipping or is it maybe my slave cylinder ? Please help
Old 09-04-2012, 04:33 PM
MKE_Audi's Avatar
check your brake fluid, it is the reservior for both the brakes and slave cylinder.
Old 09-04-2012, 09:58 PM
z28pete's Avatar
If the RPM go up but the MPH do not, then the clutch is slipping. The lack of fluid in the clutch plumbing does not affect slippage, but prevents you from releasing the clutch to shift gears. From your story, it would seem a new clutch is needed.
Old 09-24-2012, 10:56 PM
ethic's Avatar
New clutch time! I went ECS Stage 2 with new flywheel, it comes out of the shop tomorrow. I will re post on how it feels and works.
Old 09-28-2012, 08:12 PM
Ncbaca's Avatar
I went with the south bend clutch stage 2 endurance lets see how it works should be out of the shop soon. I kept my steel flywheel but im unsure if i should replace that to and if so aluminum or stay with steel. Thanks for all the replies everyone big help
Old 09-29-2012, 09:10 AM
ethic's Avatar
Replace the flywheel or your clutch could last half as long. I replaced mine.
Old 10-19-2012, 07:01 PM
Ncbaca's Avatar
Thanks for all the help everyone
Old 10-30-2012, 10:31 PM
HARDCORE CHINO's Avatar
so what kind of clutch you get? how does it feel and how was the price?
Old 10-31-2012, 11:31 AM
ethic's Avatar
Hey, I have had my ECS stage 2 clutch with flywheel in for about a month now and it is great. Seems to be geard torwd more spirited driving. No complaints or problems so far. It will take you a couple of days to master the new clutch thoug; Its a tad diffrent. I will post a more detailed report when i get home.
Old 10-31-2012, 03:59 PM
ECS Tuning's Avatar
Sponsor
OP,
It could be that your rear main seal is leaking and getting oil on the clutch causing it to slip as well. I would definitely keep an eye on it.
Glad to hear you are enjoying the clutch! Thanks for the support!
Jason
Quick Reply: Clutch slipping?
