clutch issue
Old 04-04-2008 | 11:04 PM
49erA4's Avatar
Default clutch issue
So I just had a new clutch put in my A4 and i've noticed a big difference in where the clutch catches (almost all the way depressed) instead of halfway depressed. Also it catches much faster. Is this something that can be adjusted or something I'll just have to get used to? If it can be adjusted is this something that's adjusted easily?
Old 04-05-2008 | 12:15 AM
amiller86's Avatar
Default RE: clutch issue
I'm pretty sure I've read herethat Audi clutches are self adjusting.. Without knowing what kinda of parts etc.. I would say that when the clutch is first breaking in you will notice much sharper and quicker engagement. It should settle back to normal, I would assume
Old 04-05-2008 | 12:04 PM
Papachristou's Avatar
the clutch self adjusts, if you installed a better clutch like OFE SS or FE SS, the engagement point is much lower and cannot be changed
dolceto
07-21-2012 06:54 PM
joeyac02
03-03-2012 05:01 PM
Waidesworld
12-21-2009 02:14 PM
audilover77
03-07-2009 06:19 PM
wlgaddey
02-06-2008 05:52 PM
