Is the 'check engine light' on due to 'coolant & oil pressure' lights on dashboard?
Old 05-23-2011 | 05:46 PM
ssingh's Avatar
Default Is the 'check engine light' on due to 'coolant & oil pressure' lights on dashboard?
Is check engine light on due to Code 'P0030 HO2 Bank 1 Sen 1 Heated Circuit' Or due to the red coolant & oil lights i have on dashboard?
Old 05-23-2011 | 10:24 PM
Audi Tek's Avatar
Tech Certified
Common sense would tell you.... the fault in the ECM is why the check engine light is on.
You need to replace that sensor.
Old 05-24-2011 | 07:54 AM
ssingh's Avatar
Um its not common sense actually its experience and im a newbie
neways there are few types of oxygens, which one to replace?
Jmineses_201
03-05-2015 11:33 PM
cipi888
07-16-2013 06:11 PM
MoneyG
01-06-2008 06:22 PM
ttjenny
06-22-2005 08:39 PM
