Changing Front Blinker Light
Probably easy, but I am not all that mechanically inclined. My right front blinker light has gone out. Is this something that I can change myself? If so could someone give me a clue as to how. I lifted the hood and took a quick look at the housing. It appears to have a gasket around it. I am not sure what tools if any I will need. Is something I should attempt or not? Thanks!!
RE: Changing Front Blinker Light
Actually its fairly easy. Take out the two phillips screws that are holding your intake on and pull out the intake. Then take out the two torx bolts on top holding your headlight assembly in that are easily visible. Then loosen, but do not remove two more torx bolts that are found behind the headlight assembly and about 5 inches down (these are not as easy to find). Then pull out the headlight assembly. You may or may not have to disconnect the wiring to the headlights but it's two simple connectors. Then from the back of the headlight assembly, turn the part that holds the blinker, about a quarter turn and pull it out. Replace the bulb and there you go.
